Today i finally got around to begin putting together my X99 build with all of my parts arriving. Except on little minor problem - I think my MSI board came with bent pins. As soon as the cover came off, I noticed what looked like bent pins. I can't really test the board out unless I buy a heat sink as this will be a water cooled build. Should I just send this back to Newegg? Or will they just pin this on me (no pun intended). I also don't know if the MSI boxes come factory sealed (I don't remember my Z77 Power being sealed) but this also did not, but that wasn't something I was or wasn't expecting.
I've seen boards with bent pins before and it really jumps out. Almost like there are no pins. This one is hard for me to tell or at least the extent of how bad it could be. I did try putting in the 5960x and then taking it out to see it would make them worse, but no difference.
