bent heatpipe
morkboy_wonder
I accidently stood on a thermalright hr-03 which I have an bent one of the heatpipes. It is not kinked and I can't see any holes in it. Do you think it will be ok to bend back and use?
Yea, that should be fine, as long as theres no kink and or hole. Even if it was slightly kinked it wouldnt effect anything that much. Its worth putting it on and see. At worst you might lose a little cooling potential, but nothing thats going to cause your CPU to melt or burst into flames :D
Yes I was worried someone might ask that. It was a combination of a small bedroom and lots of alcohol.
