BenQ XL2420TE Picture Problems
Ownageske
Hey guys,
Recently bought the new BenQ XL2420TE have only had it a few days and have noticed problems from the out go. Have noticed in gradient heavy photos they come pixellated or look like you are pushing your finger on the screen. The best example of this is when the login screen for windows comes up:
Does not matter what preset I have it on they all have varying degrees of this bad image quality including the standard mode.
It also has screen stutter episodes when I am scrolling down pages a line of screen stutter that will slowly make its way up the screen until it reaches the top then begins again down the bottom. Changing the Hertz of the monitor increased or decreases the intensity of the stutter but it is still there on 144Hertz.
Want to get your guys opinion on the problem if its hardware/settings problem or if I have a faulty panel and should return it. Never had a problem with any of my other monitors that I have had set up to the same rig.
Cheers
It's actually impressive how bad that is. I'm no expert but I think you've got a defective one.
Assuming the monitor's drivers are installed, your OS is running 32 bit color/set to 144hz in the OS/GPU driver settings and you've eliminated bad cables as a possibility I'd send it in for replacement.
I'm getting this as well, most noticeable on the steam homepage
I can't say the monitor is "Broken" Because I had this problem with my XL2420T for like two months after I got it, after which several driver installs and connecting the monitor up 3-4 different ways it fixed itself
Its the worse at 144mhz, less at 120mhz etc just like you reported, its definitely videocard/driver related, I just can't pinpoint where/how to fix this, just after several driver installs etc it fixed itself
*EDIT* I Fixed it!
Problem was using both DVI-D slots, apparently this monitor hates that
Disabling the second DVI and hooking up a HDMI monitor completely fixed the problem
EDIT2: The problem is back again, even if using display port
And no, I didn't hook it up with HDMI, I hooked it up with DVI-D to the BenQ
That said, I changed cables and I saw a LITTLE signal improvement, which leads me to believe my signal problems may be due to interference in my room somehow
