BenQ V2400W Power button problem.
FourPlay
The power button on the monitor has been faulty since day 1, but it was never such a big deal. All the other buttons work perfectly. The button itself is a touch sensor (I believe) and it wont turn off when I put my finger on it/press it. I used to have to rub my fingers together then touch the button in order to get it to turn off. Now nothing works. I don't want to return it as it will be too much of a hassle. Does anyone know any way I could possibly turn it off (apart from at the wall)? I'm not turning it off at the wall as my TV etc are on the same board.
Thanks in advance for any help.
Why do you want to turn it off anyway? You can leave it in the stand-by mode, can't you?
I don't like sleeping in a room lit up by a little orange light.
So can anyone actually answer my question?
