BenQ v2400w Button Issues
Kalabalana
My Auto, Menu, and Enter buttons seem to not work.
Anyone else had this issue and/or found a resolution?
Sorry if this has already been discussed, I couldn't find the search function.
For those particular buttons, you have to tap it lightly once to activate, then tap it again.
Only the Power button works on first touch. Give it a try. I thought I had issues with my buttons too, but I've since gotten use to it.
hmmm, I'm on a DVI connection, is there a possibility that the buttons would be disabled as a result?
(P.S. Thanks for the response, I will def give it some time, but still looking for other possible solutions)
AHAH, yes the auto feature is disabled, and after just touching the menu button for a while, it magically now works! Thanks for the heads up!
BTW do you know of any eye-inspection methods to calibrate my monitors color?
What I did to calibrate my monitor is to use pictures I had taken of my house such as th furniture, the wall, etc. and adjust the video card settings to match the colors of the pictures to what it was in real life. For example, I had a picture of my desk (which I'm still using with my V2400W) with my old monitor and I adjusted the picture of my desk on the V2400W to match the 'real' colors of my desk.
I know it's not the most scientific method, but it worked great for me. There wasn't too much adjusting that needed to be done as this monitor is calibrated pretty good out of the box.
Don’t laugh but with the Enter Button issue, the only way I could get it work was by slightly moistening the finger on the tongue and touching the bottom left hand corner of the Enter Button.
Perhaps someone who knows what electrical effect is needed could explain. After that I tried tap water and earthing myself with the other hand – neither of which seemed to work.
You really must have a D-sub or DVI cable if you want your monitor to power down after shutdown etc. An HDMI cable will only give you an all blue screen which I guess is a entertainment screen (tv) convention.
No kidding about that Enter button. I received my V2400W today and took me little bit to get the hang of that button.
