Benq G2400WD or E2400HD?
roorooroo
Choosing between these two at the moment..not sure which to for..mainly for playing PC games, maybe the odd 360 and PS3 game too.
Specs seem to be the same except for resolution. (in UK but Benq website specs aren't always correct!).
Thanks for the any suggestions.
Roo
Okay well, there are those two i am looking at..but..
I can buy a Dell 24 incher with a great dead pixel guarantee which seems to be a deal clincher at the moment..any of the cheaper 24 inch Dells would be affordable for me so any suggestions for an avid gamer (i've heard about Dell's input lag problems).
Gaming and image quality are my preferences.
I'm looking at:
Benq G2400WD
Benq E2400HD
Dell S2409W (REV A01)
Dell E248WFP
Load of reviews and such, but each one seems to contradict the other!
Cheers.
To copy and paste from a post I made earlier:
The G2400WD has 1:1 pixel mapping, dynamic contrast (disabled by default, which is good) and overdrive (disabled by default, which is good), while the G2400W does not.
As near as I can tell from googling, the G2400WT adds an adjustable height stand to the G2400WD, and is otherwise the same.
For your criteria, the G2400WD is probably the best choice. The G2400WD is listed on the Anandtech LCD Thread as the best 24" monitor in the Hardcore Gaming category, so it's the safe way to go.
Yep thanks evilsofa, thought the G2400WD would be the recommended one to go for..now to find somewhere in UK that has a good dead pixel deal.
