Benq FP241W(Z) blackout problem
Discussion in 'Displays' started by fenix123, Apr 10, 2007.
  1. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
    Hi, this is my first post to this forum, but I have been lurking around about a year or so.
    Recently I have bought Benq FP241WZ monitor. I am very satisfied with it, only thing that bugs me is the blackout problem.
    I have connected it to DVI port at ATI Radeon 8500 (flashed with 9100 firmware). The blackout lasts 1-2 secs and occurs few times a day. I am planning to upgrade my hardware and so the graphic card also. So I am wondering with what graphic cards there is no blackout problem? I have gone through FP241W and Z threads and as I can figure there is no problem with NVIDIA cards?
    So please if you don't have blackout problem could you post your graphic card model? Also if someone was able to fix this problem with changing DVI cable could you post exactly brand and type of third party cable?
  2. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
  3. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
    bump
    so i can assume that everyone has blackout problem with these monitors?
  4. Luthorcrow
    Luthorcrow [H]ard|Gawd
    1,242
    Dec 21, 2002
  5. jamiee
    jamiee Limp Gawd
    311
    May 21, 2006
    I'm running a BFG 8800GTX and don't have this issue.
    It seems to me most that do, own ATi cards.
  6. kryptolus
    kryptolus [H]Lite
    66
    Oct 30, 2006
    Are you using the cable included with the monitor?
    Some people reported that the problem went away with a different ("better") cable.
  7. WickedWeasel
    WickedWeasel Limp Gawd
    444
    Jul 13, 2004
    Is there a message when the screen blacks out? "DVI connection lost" or something like that? I was testing the FP241VW monitor at the store and it did that a few times.
  8. rajravat
    rajravat n00b
    5
    Apr 13, 2007
    i have a ati x800xt card and i dont have this problem, im using the DVI cable that came with my dell 2005FPW monitor.
    a few people are saying it could be a driver/cable isse in that large thread for people who do suffer from it
  9. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
    Tnx guys for some feedback. I have started new thread because I was looking for a solution in "main" threads for these monitors and I couldn't find one. There are just to many posts there.
    So I imagined we could post here graphic card and dvi cable configuration and state if we have or don't have blackout problem. This could maybe help us to isolate this problem to specific graphic cards and/or dvi cable combination.
    Here are my specs:
    monitor: FP241WZ
    graphic card: ATI Radeon 8500 (flashed with 9100 firmware)
    dvi cable: original, included with monitor
    blackout: occurs few times a day
  10. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
    there is no message, only black screen for 1-2 secs
  11. jamiee
    jamiee Limp Gawd
    311
    May 21, 2006
    Yup, I'm using the DVI cable that came with the screen.
  12. vxyleme
    vxyleme n00b
    7
    Apr 28, 2007
    I have the blackout problem. It has also been referred to as the signal loss or flicker problem. Whatever you want to call it, it's when the screen blacks out for about 2 seconds then goes back to normal. This only occurs in DVI-D mode when connected to a computer.
    This problem is indeed a great conundrum as even I, despite my greatest efforts, have been unable to solve it. It is for this reason, and this reason alone, that I have come to you today to post my account on this horrible problem and ask for help from the community that is located on this internet forum at hardforum.com.
    Does anyone have a solution that definitely fixes it? In other words, has anyone had the problem, applied some solution or combination of solutions, and has not seen a single recurrence for a significant amount of time (i.e. more than 200 hours)?
    Has anyone with the 1:1 firmware update had the blackout problem in DVI mode, or is this problem limited to the original firmware?
    I should mention that I'm using an ATI graphics card, have the original FP241W firmware and original DVI cable, and experience the blackout problem randomly about once every 24 hours for 2 seconds.
  13. MrPatate
    MrPatate Gawd
    1,023
    Jan 4, 2007
    True
    False
    I had the same problem with my 9600Pro, RMA the monitor, currently looking for a new one. The question is, is this problem related to old ati or new ones two?
  14. Joe Fission
    Joe Fission Limp Gawd
    167
    Jan 15, 2006
    I also encountered the blackout problem, but only after switching to a better quality DVI cable. The blackout would occur randomly but about once a day and would last for 1 to 2 seconds as others have described. I tried different drivers, tried the "changing sync polarities to positive" thing that someone else posted in another thread, and reset the screen back to factory settings thinking maybe it was something that I changed in one of the menus that was causing it and it didn't go away. I then tried the only other thing I could think of which was to remove the high quality Monster DVI cable and go back to the original cable that was shipped with the monitor and I haven't had the problem since. For 3 days I've been testing and making adjustments and whatnot and the problem still has not occurred to my knowledge. I'm not in front of my monitor for the entire period it's on however, so the blackout problem may have occurred when I was away and I just wasn't there to see it. So, as far as I know it's not happening anymore.
    I'm using a 8800GTS with 97.92 drivers on Windows XP.
    Ya, just watch though, now that I've said that it's going to get worse.... that would just be my luck.
  15. Tri
    Tri n00b
    25
    Apr 30, 2007
    I have this blackout problem with my Samsung 20inch LCD with ATI 1900XT card.
  16. fenix123
    fenix123 n00b
    7
    Apr 10, 2007
    At Benq "monster" thread Sinister Crayon posted nice template for gathering information about blackout problem. So please could everyone post their specs, especially if you don't have this problem. Help us resolving this.
    Ok so here are mine specs:
    Also here is empty formated template that you can easily copy&paste:
    HTML:
    [QUOTE]
    [B]Problem Present:[/B]
    [B]Monitor:[/B]
    [B]GFX card:[/B]
    [B]GFX Driver Version:[/B]
    [B]Operating System(s):[/B]
    [B]DVI/VGA/etc cable used:[/B]
    [B]Power source:[/B]
    [B]Monitor backlight setting:[/B]
    [B]Problem occurs when:[/B]
    [B]Temporary fixes/treatments:[/B]
    [B]Permanent fixes:[/B]
    [B]Other:[/B]
    [/QUOTE]
  17. vxyleme
    vxyleme n00b
    7
    Apr 28, 2007
    I shall join this cause to help provide a solution for myself and the community.
  18. bitgod
    bitgod Gawd
    994
    Feb 20, 2003
    This happens just enough to remind me it happens, but not enough to piss me off yet. The first time it does it while playing an action game will probably change that view. Other than that, I love the display quality, it looks a lot better than my old 2005FPW.
  19. Sinister Crayon
    Sinister Crayon Gawd
    669
    Jan 27, 2007
    Hmmm, this is not looking good....
    Out of the few posts we do have... I see no correlations....
    Maybe its a certain panel batch..... gahhh!!!!!!!!!!!!!!!!!!!!!
  20. AFTFNJ
    AFTFNJ Limp Gawd
    297
    Apr 5, 2007
    Problem Present: Blacks out randomly for a few seconds.
    Monitor: Benq FP241W
    GFX card: XFX 7600 GS
    GFX Driver Version: 6.14.11.6371
    Operating System(s): Windows XP SP1
    DVI/VGA/etc cable used: DVI -D The one that came with it.
    Power source: surge / battery backup
    Monitor backlight setting: 90
    Problem occurs when:More likely to black out if I power off the monitor & start it everyday. Has blacked out right after starting. Also blacks out when opening web pages in new tabs using middle scroll mouse button in Firefox. Never blacked out in Fear or UT Demo.
    Temporary fixes/treatments: Pray
    Permanent fixes:Pray
    Other: Benq Support sucks ass. If you need help with there products you will be screwed. JAN 07 manufacture date purchased from NCIX.
  21. negitoro7
    negitoro7 n00b
    26
    Nov 10, 2007
    Have there been reports of this blackout problem occurring with FP241VW models too?
  22. MishimaKazama
    MishimaKazama n00b
    56
    May 9, 2007
    for the record, my monitor went haywire once when hooked up to my 360. Here's a video I shot.:
    http://youtube.com/watch?v=3UrVxtIxfu4
    It only happened once and it hasn't happened since.
    It does also suffer from the typical DVD-D blackout problem, although it's not too bad; it only happens once in a great while. In fact, I think I've only had it blackout on me 5 or 6 times since I got it earlier this year.
  23. AFTFNJ
    AFTFNJ Limp Gawd
    297
    Apr 5, 2007
    Can you give us more details?
  24. RB30
    RB30 Limp Gawd
    480
    Sep 16, 2007
    I have a FP241WZ and used to have blackout problem a few times before. Well, that was when I hooked up to an Apple Macbook in my bedroom. The blackout problem at first started on the 2nd or third day after I got this monitor.
    Now I hooked up my FP241WZ to eVGA 8800 Ultra, no more blackout problem at least for 2 weeks now (knock on wood...).
    So I figure this blackout problem could be due to video card or power usage, where Macbook with a DVI adapter is single-link and power wise is not as stable as a direct dual-link hookup from 8800 Ultra with 620W power supply.
    PS: The guy who has his FP241 gone haywire video, that is not blackout problem! Did you guys see he got some yellow triangle warning sign on the screen right before it blinked out. That is some sort of error somewhere and it is not a typical blackout problem.
  25. AFTFNJ
    AFTFNJ Limp Gawd
    297
    Apr 5, 2007
    Any updates on the damm black out issue? I am thinking to buy the EVGA 88800GT SSC. Does anybody think that will fix it?
  26. RB30
    RB30 Limp Gawd
    480
    Sep 16, 2007
    No blackout for 2 months now with 8800 Ultra....
