BenQ FP202W 20.1" Mounting Help
qbert3
So i'm not having a problem with buying a mount, i'm more so having a problem getting the back piece off thats covering the vesa 100x100 area I would be using to mount it.
I have the original FP202W (not V2 or V3).
this data spec sheet mentions it supports 100x100 vesa mounting, so I know it does...
ftp://12.145.38.159/monitor/lcd/datasheets/fp202w_specs.pdf
I'll save you the trouble:
Try harder newb.
got it, that back panel is really cut up, but a dinner knife did the job.
