BenQ BL2710PT: 2560x1440 Calibrated & Light Bleeding Free Monitor
Status
Not open for further replies.
D
Deleted member 273615
Guest
For calibration to work, the source must be identical. If you plug your monitor into GTX 680 and calibrate, then that calibration is NOT likely to be accurate for a different videocard, like R9 290X or whatever else. You have to have the display unit itself AND the identical source...
NCX
TTT
Nvidia GPU's=Same source which all follow the same standard
AMD GPU's=Same source which all follow the same standard
Status
