BenQ 24" only 21.7"??
Everest is reporting that my new M2400HD is only 21.7"...i thought it was 24" widescreen?...come to think of it, it dosen't really look like 24 inches :confused: :mad:
Field Value
Monitor Properties
Monitor Name BenQ M2400HD (Digital) [NoDB]
Monitor ID BNQ7C02
Model BENQ M2400HD
Manufacture Date Week 44 / 2008
Serial Number ******************
Max. Visible Display Size 48 cm x 27 cm (21.7")
Picture Aspect Ratio 16:9
Horizontal Frequency 30 - 83 kHz
Vertical Frequency 55 - 85 Hz
Gamma 2.20
DPMS Mode Support Active-Off
measure it diagonally from corner to corner, it should be 24".
But since this is a 16:9 as opposed to 16:10, yours should be shorter but wider than regular monitors.
These 24" 1920 x 1080 LCD monitors are actaully smaller than regular 24" 1920 x 1200 LCD monitors. The actual diagonal length is probably 23.5".
A 16:9 monitor is just as wide as a 16:10 monitor. The only difference is it is not as tall/high since there are 120 less rows of pixels.
