BenQ 19 inch LCDs
JackieO
OK so I need to find another 19 inch LCD for a family member that has both sharp text and is reasonable for gaming. In my exhaustive searching I keep ending up looking at the two <=16ms 19 inch BenQ models (FP931, 16ms, ~550), (FP937s, 12ms, ~$630). Does anyone have any information on these? Reviews? Who makes the panels (it might be BenQ), if so rebadged versions I could look at? Etc...
They seem like good deals but I'd hate to buy one sight unseen, so information is needed.
Thanks.
BenQ monitors are pretty good for their price. BenQ as i remember used to be Accer. I personally have the FP767 which is basically the same specs only in 17'. The quality is very good, except that the brightness and contrast might need to be re-adjusted for optimum use. 16ms in my opinion is fine for gaming, there isn't too much ghosting on mine and text displays are clear and sharp. Hope this helps.
