Everfalling
- Jul 12, 2005
i was thingking of doing away with the standard up and down Res made from a clear 2.5" in diameter PVC pipe and making something a little more curvey and wild. is it possible to warp and band the pipe without creating a kink where you bend it? let's say i wanna make a clean looking L bend. anyone know how i should go about doing that w/o the innerpart of the bend caving inward (like when you bend a straw at an angle)? i'm thinking i gotta heat the plastic uniformly, but i donno if the outer part of the bend will expant fast enough to keep its shape... what do you think? has this already been done?
