bending plexiglass
cobaltdog
hey all
im done framing my case mod and need to put some plexiglass paneling on it, i'de like to use one big peice just to get a more authentic look and i was wondering does anyone know if you can heat and bend plexiglass like you can to acrylic? i did a search and tried to check the article but bit-tech's in the middlie of moving things to there updated site and those files are not accessable at the moment. anyhelp will be greatly appreciated.
p.s. i will be posting a work log as soon as im done with it.
kewl thanks for the help all that last one was very helpful thanks TotalAnarchy1.
TotalAnarchy1 said:
after doing a search through my favorites, and finding the link dead, i finally found what might help you out a little
Plexi bender tutorial
THIS IS NOT MY WORK, just to clarify that
Yeah, that is Sheldon's. Great and fellow Austin Modder. He does a lot of plexi work and has made some great stuff not to mention the "Martini Mod". Makes it pretty easy to bend well and without causing the plastic to go white on you.
