Benchmark Central
Sir Random
I just made a website for storing/displaying all 3DMk scores and system specs. It updates automatically and displays the info in different formats.
Please check it out and add your specs and scores:
http://www.benchmarkcentral.net/
I just finished it this evening, so it'll look a bit bare until I get some scores on there. :)
( the server has been a bit slow today too, so please be patient)
That's odd. I have almost the exact same setup as number 1. Core 2 Duo E6700 @ 2.66, 2 gigs of G-Skill DDR2-800, and a aEVGA 8800GTX, and the most I get at those 3DMark settings is 10,975. And I have my 8800GTX overclocked a little to 605 core, and 2006 memory. Wtf?
P.S. Cool site. I'll put it in my bookmarks. :)
Update: Oh snap, I just noticed he overclocked his CPU, and videocard more than me. God damn it, overclocking the CPU seems so complicated, but I want to do it so bad. I wish there was a easy way to do it, or if I could pay someone to do it. grr
Overclocking isn't really that hard. Just follow a good guide and be patient. You should break 12k with a moderate clock.
Most Conroes are almost guaranteed to exceed 3Ghz, so the risk is fairly minimal.
Can you suggest any good guides? :)
What motherboard are you running? There's a great guide for eVGA board (and pretty much all 680i's, I imagine) sticked in eVGA's Motherboard forum.
MSI P6n SLi Platinum 650i
And yeah, I did read that long post about that motherboard, and it didn't really help. Looking for a more simplified version.
Thanks for posting your stats, guys! :)
It's still very early, but Intel have already taken a clear lead over AMD (4-1). NV and ATi are fairly close.
It'll be interesting to see how Intel/NV compare to AMD/ATi when there are enough projects to make a valid comparison. :)
I'm just blown away by Dan D's memory underclock! :)
Edit: For HARDWARE section, do you count SLI as 1 or 2? If Dan D has SLI, does he show up as 2 x 8800gtx, or just 1 user with 8800gtx? Do you go by the users or the actual cards used?
Good question!
Currently, SLI counts as one card, because both cards will have the same core and ram clocks, and the same 3DMk score. The only place it makes a difference is in hardware totals, where 'technically' it should count as 2 cards.
Do you think I should count SLI/Xfire as 2 cards when adding up hardware totals? I can easily change it.
UPDATE:
TEAMS have now been added, so members of [H]ard forums can now edit their projects to select the [H]ard team (or any other team).
You can also request new teams to be added, so any group/forum can now have their own private database of scores :D.
