sitalchauhan
- May 30, 2006
As I currently do not have a wireless router and am getting fed up with the wires, I have deicded to get a wireless router. However, the distance from my living room on ground floor (where internet connection is) to my bedroom in the loft is quite far, so I am thinking of getting an n router instead of g as it apparently works better over large distances.
However, I would rather buy a cheaper router now and then get a much better one once the final n specification has been made.
I have done some research and the Belkin Pre-N seems to be the best value for money. Is this a good choice?
I want to get a USB wireless card for my laptop, and not PCMIA (so that I can use it in a desktop if needed). However, looking around I cannot find a belkin USB adaptor that is of the same 'pre-n' series as the router.
Therefore, please could somebody recommend a usb wifi that will work at n speeds (not g) and is compatiable with the Belkin Pre-N router?
Many thanks,
Sital
Many thanks,
Sital
