Hey Everyone,
I wondering what would be a good Beginners Water Cooling Kit, I have a Thermaltake Armour and would like a Incase kit to cool my 4400+ and possibly my 2 7600GTs
What would be the best Kit to start with ?
thanks
-Raven
A bit from column A, a bit from column B
I would like to be able to push my machine, but I would like it to look good too
Not to worried about the noise, my case is already noisy
Well, its a starting kit, so I dont really want to spend to much, mainly want something which is reliable and wont turn my PC into a fishtank
For $250 dollar you can start off with a Swiftech H20 Apex 220 kit: http://www.newegg.com/Product/Product.aspx?Item=N82E16835108076
It's got very detailed installation instructions with pictures and includes a bunch of performance parts that will grant you great temps if you decide to ramp up your OC. It can also handle GPU upgrades somewhere down the line.
However, if you're more technically minded and don't need instructions you can piece together an awesome performing loop for the same price:
D-Tek FuZion CPU waterblock: $65 @ Petrastechshop.com
Swiftech MCR220QP Radiator: $40 @ jab-tech.com
Laing DDC-2 w/ Petra's modded top pump: $100 @ Petra's
Swiftech mcres-micro reservoir: $20 @ Petra's
10 feet of Masterkleer 1/2" ID tubing: $5 @ Petra's.
It's about the same price after shipping and you'll have a system that will rival the cooling potential of many others out there. The clear tubing and reservoir can be light up with UV dyes added to your distilled water solution. This kit will allow you to expand itself by adding a GPU block down the line without any problems.
Tubing: 7/16" Masterkleer (10 to 15 ft)
T fitting for a T-line
use zip ties for hose clamps, they will work fine when you push the 7/16" tubing over the 1/2" barbs on all the gear.
Fans: if you have the money and you want silence plus performance get the Scythe S-flex fans
What about external water cooling????? I can help there as some people already know about![]()
If you don't mind me posting:
http://www.petrastechshop.com/newa.html
BTW, did you use to work at Sharka?
YESDid you make that little jewel?
What would make you think that![]()
Although I would like to... paper route can't satisfy the monetary requirements of a 17-year old's computer hobby![]()
Just grab:
Fuzion CPU block
MCR320 or 220 depending on what you can fit
MCP655 or DDC+ with a modded top.
Some yate loons
Masterkleer tubing
You're done. Seriously, kits just arn't worth it these days.
