beginners complete watercooling kit?
jEnkinsX
i wanna to try water cooling just for the heck of it.. so i was wondering if there is a kit out there that comes complete (pump/rad/fans/tubing/cpu/gpu/chipset waterblocks)... these are the specs of my computer
AMD Athlon XP 2500 barton stock
Thermalright Sp97
Zalman NB-47J NB cooler
ATI 9800pro
Abit NF7-S Rev2.0
maybe some OCZ 512 DC kit but right now generic 256MB DDR400
ive seen the Asetek WaterChill 2 Water Cooling Kit but is that the best complete kit i can buy? what other brands should i look for?
I recomend the Swiftech APEX kit. that kit is about as complete as complete gets.
it brings everything that you'll need except for distilled water.
I used a Koolance case for about a year and it worked great, kept my setup cool. Was running an amd 2400XP back then. I stopped using it when I upgraded to athlon64 and because when I started I used distilled water like it said but Koolance has since changed to special liquid. I still have the case sitting in my apartment but I have a feeling I would be destroying an Ecosystem if I turned it on now. There is a lot of green junk in the tubes... I will probably clean it out someday.
