Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Because the PSU is on the bottom of the case will i need any adaptors to reach the top parts of the mobo etc, well i seen people in the past need extension cables etc in some cases.
I got a Cooler master 600 watt igreen PSU if this helps
You should be fine. Most 24 pin power cables are more than long enough to reach where they need to and while your 4/8 pin may not be long enough the 932 comes with an extension cable.
