beeping motherboard?
KeymaN
Hey guys
Recently i just transfer one of my system from one case to another
I didn't change any of the hardware at all just a simple case swap
But weird thing happen after I finish the swap
Once i finish piecing it back together and have the power on
The motherboard starting to beep quietly
On the motherboard, the start and reset button on it is blinking as well
Usually it stays on
It looks like the power kept on going on and off
I am wondering is this the PSU problem? or the motherboard?
PSU = Corsair HX850
Mobo = Rampage II Gene
Please help! Thanks!
KeymaN
I am wondering if there is a short in the board/its not grounded properly? But as Andrew_Carr suggested listen to the pattern of the beeps, the referr to your mobo manual.
Did you check the stand offs for any in a bad place like an extra one at the matx hole near the expansion slots that would interfere with a full atx board? Had one overlooked there once on a mainboard swap myself.
