Beep Errors, I'm clueless
HybReD1234
I've recently put together this build and have been having all sorts of errors with it. The beep error is 1 with a pause, 7 more, and then a final beep at the end about 5 seconds later.
Typically when the extended beeps happen it's a motherboard/CPU issue, I've replaced both.
XFX 280GTX
A Foxconn board
2x2GB of G.SKILL
E8400
PCP&C 750W
I've never had a PC give me this many problems and I'm completely clueless as to why this is happening. With the old Gigabyte P45 board the beeps were much more spread apart.
I've tried booting without the video card, same issue. I've reset the CMOS, swapped around RAM, swapped CPU's, motherboards... so I'm clueless to what the issue could be.
Any ideas?
