Which APU in particular? A lot of them are simply re-using the Bulldozer/Piledriver cores/modules setup and squeezing a GPU onto the package alongside either 1 or 2 modules (2 or 4 'cores'). The CPU performance is behind Intel at a given price point, but may allow you to get away without a dedicated GPU in the build, depending on the workload. If that is the case, AMD offers a decent bang-for-the-buck.
Been Gone 5 Years
Was looking on AT and see Godaravi benchmarks. So I will assume the older FX series are still faster than these apu's even though its been years since a new FX model?
Can some one educate me on amd cpus?
what is the diff between the old FX series of 2012-2013 compared to these apu's?
Friend asked for advice on building and I am stumped.![]()
Don't worry, so has AMD.
Let your good memories stay that way. AMD is the tech equivalent of a drug-addicted child-star at this point.
I really don't get this attitude, neither AMD or Intel has really focused on performance improvement in the last 5 years and the PC market has been slow. Intel and AMD have mostly been focused on power savings. AMD went for higher core-counts, Intel went for higher IPC. Either architecture is perfectly adequate for media and 1080p gaming.
I have an i7 4930k in one desktop and an FX 8320 in another. I really don't notice the difference unless I'm playing something that is very CPU-intensive and not heavily multi-threaded, like Kerbal Space Program. That and the AMD build didn't rape my wallet.
