R1ckCa1n said:won't work! I tried it already.......![]()
freaking DFI board is just a few mm off and it would work.
tbooth said:Damn, I mounted my Cuplex XT with the springs underneath the block (they seemed much too long to put on top) Guess I'll try it the other way when I get my motherboard back from RMA.
J-M-E said:Great, looks like ill be taking the twinplex off...
Top Nurse said:Well the new TwinPlex Pro is supposed to be thin enough to work on that board.Unfortunately some a-hole mentioned to them that their blocks were concave so all that stuff is on hold while they fix their mill.
Top Nurse said:I originally did the same thing as you , but then I asked on the AC Forum and some a-hole over there told me to RTFM even though it was in German. If they are to long did you use the machine screw or the post that screws into the backing plate. The post was to short on my A8N-SLI board.![]()
tbooth said:The screws I used were the longer of the 2 sets (these don't have the nut connected to them) but the springs still stuck way over the top of the screws. I removed the back plate too.
J-M-E said:The springs are supposed to stick over the screws, you push them down with the nut, causing them to apply pressure to the cpu and keep the waterblock in place...
tbooth said:Gotcha. I couldnt even get the nut onto the screw without what seemed like an extraordinary amount of pressure. I guess next time I'll try and be less worried about crushing the CPU.
eumskickin said:who was that a-hole ..... i need a block for my DFI and i don't care if i have to lap it or scrape it
DFI Daishi said:OCZ and DFI.....both in the same system.....it makes me hurt inside.......
anyhow, have you read up on the 5 volt VDIMM jumper issue?
and if you EVER have something that resembles a cold boot problem, something that works more often that it should to get that thing living, and is a lot less risky than most of the cold boot procedures, is to slap a PCI vid card in there.
for some reason, DFI boards sometimes look for the PCI vid card that they are set by default to initialize first, find one that isn't there, and continue to post and boot without checking the AGP bus.
putting a PCI card in there lets you get into the BIOS and set the board to look for an AGP card first, and continue on from there normally.
my NF2 has that problem, and the same thing crops up from time to time on their more recent nForce boards as well.
my hatred for DFI knows very few bounds.
they boned a friend of mine on a very expensive pair of dual channel BH-5 sticks that would not even hit stock speeds within the allowable voltage range.J-M-E said:OCZ makes insanely overclockable ram thats stable and speedbinned. And DFI has the most options of any motherboard ive ever seen. Whats your problem with OCZ?
DFI Daishi said:they boned a friend of mine on a very expensive pair of dual channel BH-5 sticks that would not even hit stock speeds within the allowable voltage range.
OCZ also has a history, which most people now consider to be well behind the current face of the company, of producing sticks that need a lot of voltage to hit stock speeds. their current stuff is supposed to be better about that particular issue, and their warrenty coverage is good these days, but it didn't used to be.
i guess that you could say that i am holding a grudge.
and just BTW, UTT memory is, by definition, not speed binned by winbond. if OCZ is speed binning individual chips themselves after the fact.....oh well, problem solved. i just don't know that they are doing so, and quite frankly doubt it.
yes, the board can supply up to 4 volts if you move the 5 volt VDIMM jumper into the 5 volt position.J-M-E said:This VX 4000 Gold ram I bought uses UTT CH-5 chips. It DOES require a lot of voltage, but the DFI can provide up to 4 volts, which makes this set up work awesome together![]()
OCZ plat = samsung TCCD chips, not winbond.MikeyB said:I like the barbs you have on your AC gear. Never was a fan of the push fits.
WRT OCZ
I bought 2x512 OCZ plat. rev. 2 and it hit well over 300mhz at 2.5-4-3-7
I'm under the impression that the only OCZ parts not speedbinned are the value series rams. If you buy vx3200 you are likely getting sticks that didn't make the vx4000 cut. OCZ seems fine to me.
i have had 4 boards in the last 24 months. of them all, i had by far the best experience with my NF7-S rev. 2.0 board. then i went and quite spectacularly cooked it.R1ckCa1n said:I have had over 10 boards in the past 24 months and find DFI to be the best, by a far margin. If people are SO concerned about the potential 5volt problem, you can use a RAM Booster to acheive the desired voltage. I am running my VX @ 265 2,2,2,5 1T (3.2volt) with zero issues.
I would blame your power supply more than a board at this point (not the best for real overclocking). I did not start to achieve nice stable overclocks until I switched to my OCZ power supply. I have both the NF-7 Rev1 and Rev2 but they don't compare to the quality of DFI boards. I can't wait for the crossfire edition DFI is making! !~!DFI Daishi said:i have had 4 boards in the last 24 months. of them all, i had by far the best experience with my NF7-S rev. 2.0 board. then i went and quite spectacularly cooked it.
i wanted to get past 230 FSB, and i thought that DFI was the way to do it, having read the stories of people who got them, and had them work properly.
POW! right in the jimmies for me!
i have come across several others online who have had really bad experiences with their DFI boards. in the face of all of the people touting the virtues of these boards, i just want to make sure that there is at least some warning for a young user saving up and looking for a board, that buying DFI and overclocking is not a sure-fire path to high-performance and reliable computing, for a reduced price as compared to getting a top flight CPU.
i know that every board has good units and bad ones. there is just SO MUCH good press about the DFI boards that i feel the need to be a voice of caution.
umm.....please notice that i was previously using that NF7 and getting at least SOME overclock. also, i have tried a nice antec 550 watt on loan, that did not do a thing to help my ability to FSB overclock. low multies don't help, high voltages don't help, and my PSU's output is rock solid as probed with a multimeter while under load, overclocked to my current setting, and while experimenting with FSB overclocking. i have done everything reasonably possible to isolate where my problem lies, and the board is what i come back with.R1ckCa1n said:I would blame your power supply more than a board at this point (not the best for real overclocking). I did not start to achieve nice stable overclocks until I switched to my OCZ power supply. I have both the NF-7 Rev1 and Rev2 but they don't compare to the quality of DFI boards. I can't wait for the crossfire edition DFI is making! !~!![]()
DamienThorn said:
R1ckCa1n said:Server grade has nothing to do with how well it will perform with a CPU at high voltage, a video card at high voltage, and RAM pushing serious voltage. Server grade power supplies are for long term reliablity. Check the inside of all the top overclockers and you will not find Antec and such....![]()
I hate to see people blame a motherboard or CPU when they run cheap ram and power supplies.
Correct! He should get something with all the cooling he is using but to blame a board that is know as the best overclocking board made is silly.DamienThorn said:Unless I'm very mistaken, there shouldn't be a significant issue getting some wicked OCs using the RAM that DFI Daishi is using. At the same time, assuming that I accept your hypothesis that he doesn't have an "overclocking PSU" he should be able to hit far higher OCs that he is currently able to. He may not be able to hit the best OCs in the world, but he certainly shouldn't be constrained in his OCs like he currently is.
and DFI has never shipped a defective board out the door? ever?R1ckCa1n said:Correct! He should get something with all the cooling he is using but to blame a board that is know as the best overclocking board made is silly.![]()
DFI Daishi said:umm.....please notice that i was previously using that NF7 and getting at least SOME overclock. also, i have tried a nice antec 550 watt on loan, that did not do a thing to help my ability to FSB overclock. low multies don't help, high voltages don't help, and my PSU's output is rock solid as probed with a multimeter while under load, overclocked to my current setting, and while experimenting with FSB overclocking. i have done everything reasonably possible to isolate where my problem lies, and the board is what i come back with.
el rolio said:however: dont crap on ocz. i have the luxury myself to stat my intense purchasing of good ram basically AS THEY GOT THEIR ACT together, which means that of the bunches and bunches of sticks i have bought and that i have HAD bought by frens etc: ocz has never failed me, dissapointed or cost nearly as much as say corsair. after half a year of ocz-lovin i heard about their tattered past thru various reviews and then found out that all changed as they went under some new management and other major changes. so i had no reason to doubt any of it. and my gold sticks ARE bh-5 not utt. awesome.
