well quick q, ordering now!
thanks in advance once more... 3 parts and the end questions..
I am thinking about coupling it with either dfi lanparty n3 250gb(yes 754 mb/ cpu on top) 110 dollars (if I get it with those 2 retail cpu, I get like 15 dollars off of this m/b)
or
soltek n3 250gb (75 dollars)
i am going try to o/c tho.. but cheaper the better.. but performance matters too...
I also went to overclockers.com
and saw their database
2800+ 1.8ghz -> average oc is like 2.4 ghz (125 dollars) (retail)
3000+ 2.0ghz -> average oc is like 2.5 ghz (150 dollars) (retail)
3400+ 2.4ghz -> average oc is like 2.6 ghz (180 dollars) (oem) might get the thermalright 90 heatsink/fan
and which antec powersupply btw since you are here...? I am little bit confused with the 20 pin and 24 pin connector.. from what I learned tho.. the 24 pins p/s can be convert to 20 pins.. but 20 pin p/s can't be converted or something.. I need at least 500watt p/s
help me decide! thanks!... I been researching and reading on everything.. can't decide everything else in the comp is ready tho... but these 3 confusing things...
thanks again guys!
or
thanks again guys!
