So i happen to think that with the advent of 10gb ethernet, and fiber becoming more prevalent that more applications will take advantage of working in the cloud. I work with 3d CAD and they are already starting to move processing to a central unit. If that happens.. then i expect fully the majority of people will be returning to cheap, low power terminal stations/thin clients. Personally I think this is great as long as its secure.
That said, I would like to build a home "Core" I want to build something with a ton of power, that over the few years can be upgraded to lastest components.. something that will run multiple terminals, run the smart TV and act as a home security system monitor, and control automation devices (lights, power outlets etc) pretty much all at the same time.
Now i think i should start with the wiring. I dont think the hardware/software is there yet to do what im picturing in my mind, but by the time I get all the wiring in, and a server room in place.. MAYBE hardware will have enough cahoonies to future proof until cloud apps really start coming down.
IF you were going to take on a project like this, how would you go about it? Im thinking I should make Fiber runs to each room. Build in boxes to contain wireless AC routers and go ahead and get the server room built with full climate controls. I think the next step should by buying security system components (cameras, sensors etc ..that will probably need somthing more like a plc to control honestly) Then move on to automated light switches and power outlets. Surely by then the hardware should have kicked it up a notch. Im looking to make this a 2-3 year project before I even start on building the actual server.
Id also like to think i could make this modular.. something I could easily add memory to, or even extra processing power via video cards.. or somthing like that..
should i wait till 2020?
