HardOCP News
[H] News
- Dec 31, 1969
If you are trying to cool the CPU in your HTPC or other small form factor rig, and your stock cooler just isn't cutting it, check out Overclockers Club review of the be quiet! Shadow Rock LP today.
The Shadow Rock LP fills a niche that most other coolers can't fill, figuratively and literally. The aim of the Shadow Rock LP is to offer a cooling solution geared towards the HTPC (Home Theater PC) or small form factor PC market where space can be very limited. So the Shadow Rock LP is designed to fit in those small spaces and still deliver the necessary cooling. Using the silence-optimized Pure Wings 2 120mm PWM fan, you can be sure that the cooling will be handled in the quietest terms possible.
