BE-2400 Overclock
j1979
Has anyone got any experience o/c this chip. Its a G2 brisbane (45w) and runs cooler and less power than the G2 4400+ (65w) (ADO4400DOBOX)
there both G2s both at 2.3ghz, the only difference is the voltage the run at.
anyone got any links?
I'm searching for the same thing. I want the be-2400 in my future HTPC, passively cooled.
I have the BE-2300. I don't need to overclock it in my HTPC, but another BE-2300 I had did 2.6GHz (700MHz o/c) with stock cooling and only a minor voltage bump (0.100v) on a cheap motherboard.
The BE-2400 should overclock as well or better than other EE Brisbanes. Raising the voltage and clock speed of course uses significantly more power. Even though it starts out low power, it's easy to surpass 65W.
