Battery Powered Printer?
RuffRyder
I don't know if this is possible, but here's what I want to do and want to know if it's possible. I want to connect a photo printer, that I already have, to a laptop and be able to print portably. I was thinking about rigging a car or marine battery to a power inverter through a cigarette lighter in a project box and just plugging in the printer to the inverter. The only hitch in my plan is how can I recharge the car/marine battery after use? Since the battery won't be in a car it won't have an alternator to keep it juiced.
So how can I recharge the battery at home after use? Is it possible? :confused:
Thanks in advance.
PS. Mods if this is in the wrong forum, please move it to where it should be, I couldn't figure out where it should go. Thanks.
You can by cheap battery chargers for car batteries that will charge overnight, or in 8 to 12 hours. Is this what you mean?
So, I can charge the car battery outside of the car in my house with one of these?
You should be able too. I would suggest doing it in the garage on a work bench.
Canon said:
Yea, you can get them at almost any hardware store i've been to.
In fact... what you are describing is exactly what the "Motomaster Power Box" is.
http://gateway.canadiantire.ca/driver.php?fileid=2534374303515779_1408474395348027_845524443271701_ 600 A Power Box with 400W inverter $149 Canadian
http://gateway.canadiantire.ca/driver.php?fileid=2534374303515779_1408474395348027_845524443271700_ 300A Powerbox with 150W inverter --$99 canadian
Any US retailers that you know of carry these?
