Battery for MP4 player
JackTheKnife
I'm looking for battery for MP4 player (looks like iPod nano). Dead battery inside is 3.7V 200mAh with size: 36x20x4 mm and I have no idea which one I'm looking for. It can be more mAh then that default one. Thanks.
Do you have a picture, or a serial/model number, that we could refer to?
Hi, I am looking for the same battery - did you manage to find one? My battery does not hold a charge - the MP3/4 works while plugged into the PC but when you unplug it, it doesn't work. This is the number on the battery 042035SP 3.7v 200mAH FC28
