- Feb 16, 2003
So I'm not much of a programmer, but my company has ignored a problem with allowing our customers to restart our applications services easily. So I decided to take it upon myself to write a batch file to allow our customers to double click and it will restart our application services in the proper order. However, there's one thing I have not been able to find any information on.
Sometimes our implementers and customers will disable some of the services that they do not need in the windows services manager. I would ideally like to have the batch file check to see if a service is disabled to avoid wasting time trying to start it.
I also have another service which can take some time to stop depending on the workload it has at the time of the command to stop. So I have a fail safe system to check to see if it's still on, re-issue a stop, wait 30 seconds, re-check rinse and repeat until the service is found to be stopped.
Code:
@ECHO off
ECHO PatientWorks Auto Service Restart
ECHO PW Versions 3.4 - 4.X
ECHO on
:: Creating Event Log
eventcreate /l application /t warning /so PW-RESTART /id 1 /d "A system administrator has manually restarted the PatientWorks services by using the PW-RESTART Batch File."
:: Stopping Services
NET STOP "PATIENTWORKS SERVER MONITOR"
TIMEOUT 5
NET STOP "PATIENTWORKS DATA SERVICES" /y
TIMEOUT 10
TASKLIST | FIND /I "PWIMPORTSERVER.EXE" >NUL
IF NOT %errorlevel%==0 GOTO STEP2
:STEP2
NET STOP "PATIENTWORKS DATAFILE LISTENER"
TIMEOUT 5
TASKLIST | FIND /I "PWHL7AppServer.EXE" >NUL
IF NOT %errorlevel%==0 GOTO STEP3
:STEP3
NET STOP "PATIENTWORKS HL7 lISTENER"
TIMEOUT 5
TASKLIST | FIND /I "PWJOBServer.EXE" >NUL
IF NOT %errorlevel%==0 GOTO STEP4
:STEP4
NET STOP "PATIENTWORKS JOB SERVER"
TIMEOUT 5
TASKLIST | FIND /I "PWREDIRECTOR.EXE" >NUL
IF NOT %errorlevel%==0 GOTO STEP5
:STEP5
NET STOP "PATIENTWORKS REDIRECTOR"
TIMEOUT 5
:: Timeout while DataServices may stop
TASKLIST | FIND /I "PWDATASERVER.EXE" >NUL
IF NOT %errorlevel%==0 GOTO STARTING
IF NOT %errorlevel%==1 GOTO RETRY
:RETRY
IF NOT %errorlevel%==1 TIMEOUT 30
IF NOT %errorlevel%==1 GOTO RETRY2
:RETRY2
TIMEOUT 5
:: Starting Services
:STARTING
NET START "PATIENTWORKS DATA SERVICES"
TIMEOUT 10
NET START "PATIENTWORKS DATAFILE LISTENER"
TIMEOUT 5
NET START "PATIENTWORKS HL7 lISTENER"
TIMEOUT 5
NET START "PATIENTWORKS JOB SERVER"
TIMEOUT 5
NET START "PATIENTWORKS REDIRECTOR"
TIMEOUT 5
NET START "PATIENTWORKS SERVER MONITOR"
