Bat or Super, Aria
What theme mod should i do
  • Batman
    Votes: 11 52.4%
  • Superman
    Votes: 5 23.8%
  • Other
    Votes: 5 23.8%
  • Total voters
    21
Status
Not open for further replies.
zapperfish
I will be going with a Batman themed case but need to have some suggestions
..TO DO.. ..Suggested By..
120mm fan in front + batman grill Self
Yellow and White CCFLs (Small) Self
Well is seems to be clear that 8! people want a Batman themed case
Now i need some sugestions on what to do to the case
Planing list
- 120mm fan in front with batman grill ( 80/90mm if 1200mm does not fit)
- 2x small yellow CC's + 1x white small CC
Your sugestions will be added to the list of things to do
Well, you gotta do a blow hole with the bat symbol and get enough light to project the "Bat Signal" on the ceiling. Also, not really a mod, but in XP have your start up sound be Micheal Keaton from the first movie when he has the mugger hanging off the roof, and the mugger is screaming "who are you?" and he says " I'm Batman". Too cool. Also maybe etch Batman into the window looking up towards the "Bat Signal". Just a couple thoughts.
Status
