Bat or freezer for opteron 165
computater
Plan to OC my new Opteron 165 when it arrives but I need a hsf first. I've read around and the ninja and zalman 9500 are the top choices, but both are pretty expensive at newegg right now. (70 for zalman, and can't find the ninja) This has led me to look at other coolers, but I've yet to see any info on them. Any opinions? (Or know where to find the two top choices for cheaper?) Thanks!
Scythe Bat
http://www.newegg.com/Product/Product.asp?Item=N82E16835185009
Arctic cooling Freezer 64 pro
http://www.newegg.com/Product/Product.asp?Item=N82E16835185125
I need one that will fit a DFI Lanparty NF4 Ultra-D
For your question, I would lean toward the Arctic cooling Freezer 64 pro.
Check out Jab-Tech for lower prices on HSF. I have ordered many times from there with no issues. The Heatsink Factory has a good selection also.
Good luck.
ZZF has the Zalman 9500 for $60.00 shipped if you would like that one.
the 4-heatpipe didn't already come with his 165? he'll have to shop for it?
Unless he is buying OEM, from a monarch deal or something. However, when I went looking yesterday on ebay for the 4heatpipe stock cooler, it was around $30 shipped or more, which is the same price as an AC freezer 64 pro. From madshrips review, it looked to me like the freezer pro did what the stock HSF could do, but much quieter, minus a little airflow over the PWM. Just my small observations as I too, look towards a 165.
