I am trying to figure out some VLAN basics. I have purchased a TP-Link AP (TL-WA901ND), mostly for its inexpensive PoE capability. It supports up to 4 separate SSID/VLANs although we only need 2 isolated subnets through this AP. The AP is in a very small building with two floors, but each floor needs its own subnet. Our router is a WRT54G with DDWRT in another building bridged with NanoStations.
The first thing I need to know is do I need a managed switch between the router and AP, and if so...I can just use another WRT54G with DDWRT set up as a switch? I would prefer not to spend much on a managed switch.
If I don't need a switch, how should the router be configured so it correctly routes traffic through different VLANs? I have a couple different VLANs configured on different ports. Mostly I am not sure what port to plug the AP into and how that port should be configured...but pretty sure I do need the switch which would then send traffic to the right port on the router.
I have no experience with managed switched, but if one is needed, basic steps on how to set this up would be great. But as long as I get the confirmation that I need to switch in between, that will speed my progress up quickly. Probably could figure this out on my own eventually, but really would help if I knew if we need a switch by tomorrow. Thanks!
