Basic Systems for Parents
99rollaguy
My parents are looking to get new machines, as they're very dated (p2 450 and p2 400). They don't want me to build a system, as they want to be able to "have someone to go after" should any problems arise. They are looking at two Dell models, the E520 (with the D 925) and the E521 (with the A64 X2 Dual-Core 3600+). RAM would be 2GB on one machine (bought from newegg) and 1GB on the other (donor stick from other machine). I've been out of the loop for a while, otherwise I wouldn't be asking...
Here are the spec lists I've come up with. Keep in mind, these aren't for much more than "standard" use, they just need to upgrade badly.
E520:
Processor Pentium® D Processor 925 with Dual Core Technology (3GHz, 800FSB)
Operating System Genuine Windows® XP Home Edition
Memory 512MB Single Channel DDR2 SDRAM at 667MHz - 1DIMM
Keyboard Dell USB Keyboard
Monitor 20 inch E207WFP Widescreen Digital Flat Panel
Video Cards Intel® Graphics Media Accelerator X3000
Hard Drives 160GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache™
Floppy Drive and Media Reader No Floppy Drive Included
Mouse Dell® 2-button USB mouse
Network Interface Integrated 10/100 Ethernet
Modem No Modem
Adobe Software Adobe® Acrobat® Reader 7.0
CD or DVD Drive 16x DVD+/-RW Drive
Sound Cards Integrated 7.1 Channel Audio
Speakers No speakers (Speakers are required to hear audio from your system)
Office Productivity Software (Pre-Intalled) No Productivity software pre-installed
Security Software No Security Subscription
Digitial Music No Digital Music Software Requested
Digital Photography Corel Snapfire Basic - Organize and Edit your photos
Warranty & Service 1 Year On-site Economy Plan
DIAL-UP INTERNET ACCESS No ISP requested
Miscellaneous E520
Purchase Intent Purchase is not intended for resale.
Labels Windows XP™
Total: $1057.88 shipped (for both)
E521:
Processor AMD Athlon™ 64 X2 Dual-Core 3600+
Video Card NVIDIA GeForce 6150 LE Integrated Graphics GPU
Hard Drive 80GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache™
Modem No Modem
CD ROM/DVD ROM 16x DVD+/-RW Drive
Office Productivity Software (Pre-Installed) No Productivity software pre-installed
Miscellaneous E521
Labels Windows XP™
Total: $994.28 shipped (for both)
Now, I'm not familiar with the boards Dell uses, but if they wanted to upgrade to aCore 2 Duo processor in the future, would that be feasible? I know not all LGA775 boards accept those, something to do with voltage on some of the Dells atleast.
Anyway, which seems like the "better" buy? The $60 difference doesn't matter much to them.
Thanks
I would lean toward the E521 (AMD system) because you can upgrade the RAM cheap via the donation you mentioned.
Good call on getting XP versus Vista.
If they are interested in saving a little money while still having someone to 'go after', check out AVA's entry level systems.
EDIT: I'm an idiot and missed that you were upgrading the RAM. But either one will work fine, although the LGA775 seems to have more leg then AM2.
I'd call Dell and see how hard it would be to upgrade to a C2D, or just get one.
For the sake of your parents......have them look at entry level Home Office from Velocity Micro.......guaranteed to get support people that speak english as a primary language.....they could even go to BestBuy and check them out before they ordered or just pick one up from there......
To me it would be worth the extra 200 dollars. You can order XP Pro on you box from VM.
