is there a way to set just set a simple username/password setup for folders to share it to certain people over a network?
Essentially what I would like to be able to do is go to any folder, right click on the folder, hit share with users(or similar button) and then be able to input usernames/passwords that can access the folder (or use pre-existing groups), change permissions (viewable/readable/editable).
Additionally, if I have a folder shared with a friend that comes over on occasion, I don't want other housemates to even see the share. Homegroups obviously won't work since you can't have multiple homegroups on a network.
I don't mind if I need software on the computer that is sharing but I can't have special software needed on clients (as they are TVs/ouya/apple tv, ect..)
EDIT: I also don't want to have to add 10 different accounts to my login screen just to share with 10 different people when only I will ever use the computer
