hey guys i bought a NZXT case it's great but it sounds like a bus when i turn it on, due to the 6 fans. the cpu heat sink and GPU card are really quite. so i am looking to purchase quieter fans.
here comes the dumb questions
when they say a fan is 120mm or 80mm what is the measurement? is it length of the side? or is it the length from a corner going 45degrees up to another corner? i gotta do some measurement before i buy fans right? lol
and any suggestions on quite fans?
