BASE,SATARAID5, SATARAIdD... bios
csnv
Anyone know what the differences between them? which one should I be using?
Need more info:
motherboard model
drive(s)
operating system
what are you trying to do? single drive install?
trying to create a RAID array? for speed? redundancy? both?
an add on card raid controller card pci -> 4port sata raid. 2 drives on it. win7 32-pro.
I dont mind to just use the drives w/o raid. should i just flash the "base" bios?
This is some info, but still not enough. What specific model is the add-in card? What is the current BIOS you have?
Got it to work last night:
BASE BIOS = not raid bios, just using the ports for disks
SATARAID5 = raid bios
I'm not sure why you need all the info to answer the question;) but thanks for trying to help...
Because different manufacturers will have things set up differently. Also, to answer the question of "which one you should be using," some information about what you plan on doing or what your end goal is would be needed to give an intelligent response.
