Right seen as im new to this and im haveing trouble overclocking i hope you can help
some basic information
ASUSTeK Computer INC.
System Model: A7N8X
BIOS Version: Phoenix Technologies, LTD ASUS A7N8X Deluxe ACPI BIOS Rev 1008
AMD Athlon(tm) XP 2500+
Version: x86 Family 6 Model 10 Stepping 0
Speed: 1830 MHz
crucial 3200 memory 1 gig
CPU-Z Report
CPU-Z version 1.28.2.
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Barton
Specification AMD Athlon(tm) XP 2500+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 1829.9 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 166.4 MHz
Bus Speed 332.7 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1829.9 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A7N8X, REV 1.xx
BIOS vendor Phoenix Technologies, LTD
BIOS revision ASUS A7N8X Deluxe ACPI BIOS Rev 1008
BIOS release date 03/29/2004
Chipset nVidia nForce2 SPP rev. A2
Southbridge nVidia nForce2 MCP-T rev. A3
Sensor chip Asus ASB100
Graphic Interface AGP
AGP Status enabled, rev. 3.0
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 256 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 166.4 MHz
FSBRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 7 clocks
# of memory modules 2
Module 0 Micron Technology DDR-SDRAM PC3200 - 512 MBytes
Module 1 Micron Technology DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX version 9.0c
Right ive just installed coolermaster aquagate external water cooler +coolermaster real power 450
Cpu temp has been steady running all night at 35 degrees
Now when i go int the bios all im doing is increasing the fsb to 200 ie takeing it straight to a 3200
The pc boots no prob into windows the problems start when i use codecreatures or 3dmark 2005 they get so far in then the pc freezes and i have to rebbot and go back into the bios
Ive tried increasing the voltage in small increments which helped to take the benchmarks a little furthe
Temps for cpu went to 38.5 degrees and still cant get it stable any ideas?
PS i have a ATI 9700pro as well
Many thx
Steve
System Model: A7N8X
Speed: 1830 MHz
CPU-Z Report
CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Barton
Package Socket A
Technology 0.13 µ
Bus Speed 332.7 MHz
L2 Location On Chip
AGP Max Rate 8x
Memory
DRAM Type DDR-SDRAM
FSBRAM 1:1
Software
Many thx
Steve
