Barebones system used for selling on eBay
tuffgong
Yes I know this is a weird one. My uncle's HP desktop just went haywire.
He wants a new computer, but on the cheap since all he does is scan pics and sell on Ebay, and play simple games like yahoo games.
He was going to spend $400. I decided that a barebones system would be good. Was looking at a Foxconn with a 2600+ Sempron, 512mb or RAM and an SATA150 80gb Hard Drive.
Any input will help me since I have never done barebones before...here are links to the three parts I need to buy. I already have the RAM and OPTICAL drive.
SYSTEM
http://www.newegg.com/product/product.asp?item=N82E16856119004
CPU
http://www.newegg.com/product/product.asp?item=N82E16819104249
STORAGE
http://www.newegg.com/product/product.asp?item=N82E16822148040
Thanks...this is pretty urgent.
Your selections look sound, although I have no experience with the Foxcon barebones system. Based on the reviews at Newegg, it seems like a solid choice. When assembled, the system should be fine for what he needs.
If you are looking to save some money, check out the complete sysem at Outpost.com. It takes up to PC3200 ram, so what you possess should be fine in it. XP installs on this system easily if you do not need/want Lindows. Find the particulars in this thread.
Good luck.
