Bare minimal, rock solid motherboard for overclocking
joshley
Hi
Following on from my other thread at the moment, it looks like I might be sending back my eVGA mobo. I've spent £189 on it, but there are three things bothering me:
1) I can't figure out (hence the other thread) whether this thing supports 1066Mhz RAM, as I've also ordered 1066Mhz Dominator TwinX RAM. The spec sheet says "DDR2 533 / 667 / 800 and support for up to 1200 Mhz". I think this means it will run at 800 and support up to 1200Mhz RAM, but that RAM will be underclocked to 800 Mhz. Am I wrong?
2) Ultimately I'd like to go SLI with my 8800GTXs, but I've heard this blocks all but one of the other expansion slots
3) I spent £189 on it, when actually I probably don't want half the stuff on there.
Here is what I want:
1) ROCK solid performance
2) Very good overclocking
3) Good expansion slots
4) Support for 1066Mhz RAM!
5) SLI support
Here is what I don't need (ideally just don't want on there):
1) Integrated sound of any kind
2) On board VGA
3) Wifi
Have I gone for the wrong motherboard?
Yes you're wrong. You can run a 1:2 divider so your cpu is at 266 and your ram is at 533 to get what you paid for.
You will have a pci-e 1x, pci-e 16x, and PCI slot free in SLI.
It is your best choice for SLI with a core2 unless you want to run hacked drivers. And IMO one of the best motherboards period...
Thanks so much for your reply chris.c, I therefore have just one (and a half) question(s) left:
"You can run a 1:2 divider so your cpu is at 266 and your ram is at 533"
OK, I have bought a E6700, will running it at 266 hamper performance? Which leads to the other 'half' question:
My spec is:
E6700
eVGA 680i Mobo
Corsair Dominator TwinX PC8500 1066
Can this all work together so each component is being taken advantage of and used to it's best ability? Or will the 1:2 divider slow something down somewhere?
Thanks again
No, your processor runs at 266 stock.
Thanks again
1:2 means your ram is running twice as fast as your cpu fsb. No it wont slow something down.
You can also drop your cpu multiplier down a couple places and run a higher fsb 1:1 with the ram. For example 450mhz x 8 (3.6ghz) 1:1 with 450mhz ram (900DDR). Even though it is a slower ram speed it will give you more bandwidth than 1066DDR and obviously much better overall performance because the CPU is running 1ghz faster...
Thanks for the pointers chris
Have I picked a good combination there for overclocking? Would I be just as well with cheaper RAM?
I bought these for $220 like 3 months ago, now that they are over $300 I can't say for certain that they are a much better value than XMS.
What I can tell you is that I have never found a need for 1066 memory, personally.
Just out of interest, why would the eVGA say just 800Mhz on the front when it fully supports much more than that?
joshley said:
Would I be better off with the Asus Striker Extreme?
The Asus is nothing more than an over-priced 680 SLI board. However, if the eVGA 680 being manufactured by Foxconn bothers you, then you can spend the extra dough on the Asus. They will overclock identically and everything will be same.
But would I be able to run my E6700 and 1066Mhz Corsair RAM at full speed with the Asus without having to run a 1:2 divider? Or even overclock the CPU on the Asus without having to underclock the RAM?
What you are asking is unrealistic. You won't be able to run your CPU at 533 FSB. Have you ever OC'd before?
All I've done OC wise it fiddle with the multiplier and FSB on my AMD Athlon 3200. I've read up, but to be honest, I've also read up posts and reviews on RAM, CPUs, PSUs, Motherboards, Cases and so on in building my new toy, and I've read up on the ins and outs of watercooling and so on and I probably know very little about overclocking. All I (think I) know is you have an FSB, and a multiplier, and you overclock by changing the FSB and the multiplier so the end result is a higher clock rate!
I bought the E6700 after reading up because it looked like with the multiplier being set to 10, that it would be easier to overclock. I also read that with higher RAM speeds overclocking becomes easier. So I bought those two in the hope that I'd have a fast, stable non-overclocked system, and can read up on which BIOS settings to fiddle later. I know there's all sorts to do with voltages and... er... other things! But I haven't done my homework as much as I should have yet!
For some reason on the C2D boards you would want to be 1:1 RAM/FSB ratio(at least with my friend's DS3). You dont have to run any dividers unless your overclocking past your RAM's rated speed/timings. For example, you put a divider on your RAM so you can overclock your CPU to whatever it can handle, then you take off the dividers on your RAM and set your timings and voltage the way you want it to be. 533 FSB is really high, and i dont believe any mobo can reach that. Its FSB x multiplier = CPU mhz. RAM is the same way, FSB x a ratio = MHZ of RAM. But to answer your question, 533 FSB is not possible.
In this case, his ram is a lot faster than his cpu fsb, twice as fast to be exact.
Correct, there is no way he will be able to reach 533 fsb, which is what it would take to run 1:1 with his ram without underclocking it (the ram).
450 fsb is possible however, and 450x6 cpu + 1:1 450 ram is better than 266x10 cpu + 1:2 533 ram. This is just hypothetical but yea, bump up the cpu fsb, underclock the ram and tighten up the timings, and you will get better performance even though your ram technically isn't running as fast as it could be.
