Hi guys,
Just came across this forum from the Shuttle homepage.
My pc performs quite well considering its almost 3 years old, so no point in replacing it. I am however thinking of upgrading her a little.
First of all I believe there silent power supply that is available. Thats one thing that really annoys me is the fan continually spinning up and down I found it link here, does anyone know if this is a straight swap in a SN41G??
http://www.dabs.com/productview.asp...&SearchKey=All&SearchMode=All&NavigationKey=0
Also thinking about the vented case to help cooling and the fan situation. May buy the remote control for what its worth??
No for my problem(s). I cant find a bios update after May 2005 is that right? Even then thats for a SN41G2. The reason I am asking is I want to upgrade the CPU and not sure what is supported, I currently have a AMD Athlon XP 1150MHZ. The bios version is Phonex Award v6.00PG
Also, why when booting up do is say Memory Frquency is at 200MHZ when the memory is actually 333MHz on both modules.
Thanks in advance for your time.
Graeme
Graeme
