Bar Code Scanner?
vk99x
I apologize if this is in the wrong section, but I'm trying to find a bar code scanner for work. My company is starting up Fiber To the Home and we're looking for the best possible bar code scanner to inventory cable boxes and customer equipment. Does anyone have experience with this and what do you recommend? I need something that is durable, and scans well. Not sure if if it would be USB or a wireless solution. Thanks in advance!!
It depends on how sophisticated you want your system to be, the more sophisticated the more spendy. I'd recommend talking it up with http://www.nationalbarcode.com/ or http://www.barcodediscount.com/ They can get you started on what you'll need. You'll probably want to have complete portable handheld scanners for the field installers and some sort of barcode printing system as well.
