Bang for the Buck VID
iNViSiGOD
Morning/Evening peeps. What with all the hype of the forthcomming Doom3 i've been thinking its time to retire me little Radeon 8500 to my server PC in flavor of something a bit newer.
The main thing im trying to figure out is this: With all these new video cards comming out, what would be a good bang for the buck when it comes to a quality VID card for anywhere from 150-200$? I dont need all the quality settings and my resolution MAXED to enjoy a game,but i dont want my PC's video card powered by a donkey and cart either.
Too much to choose from and i've been out of the gaming loop so long im not sure what to look for anymore.
Thanks in advance and Cheers!
I know my local frys is selling 9800pro (without a rebate) at $169 now. Best deal by far. Do some searching and find a cheap 9800pro. YOU CAN FIND IT CHEAPER THEN $200.
THIS IS YOUR BEST BANG FOR THE BUCK. Good luck! :p
I really don't think there's a better deal at $150-200 price point than the 9800 Pro.
The FX series, except for the 5900 obviously, is a wash. So its either the 5900 or the 9800 Pro--I'd go with the 9800, as regular 5900's are a bit harder to find now--the XT's are more mainstream now. Additionally, b/c some 9800Pros can very easily be OCed to XT speeds (of course the difference of having only 128MB memory), the 9800Pro (when found @ $170) represents an even greater value.
And of course, the fact that the 5900 is more power hungry than the 9800Pro--so if you have a crappy PSU, you might even get away with running it.
The 9800pro was actually what i was looking at getting. But i wasnt sure if i should get that or like an x600 XT.
Hehe, so much feedback. I appreciate everyones advice so far, dont want to buy a craptacular card with what little $$$ i do have.
the x600 XT is a pci-express-only equivilent of the 9600 (xt ?), so there's no real reason to get it for your system, which i assume uses agp. i'd go with the 9800 pro or the FX 5900, and probably the former.
