Bang for the buck cooling
Camskee
What does everyone like for a great, cheap solution to cooling a 1090t? I was at 210x18.5 and prime 95 was pushing the temps past 55*C. What would you all recommended?
Uhh... what are you using right now?
Hyper 212+ for anyone on a budget + fans on both sides.
Then Hyper 212+ is your best bet for a cheap cooling solution. Although the A50 has also gotten pretty cheap, no option to mount fans on both sides though.
yep at the value and second hand (which i say is still great) the corsair A50 is great and for $50 avg on the price here i say get one you won't be sorry.
Right on. Thanks for the quick replies! Guess I will be ordering one of those tonight and another fan.
Amazon has the a50 for ~$30. That would be a betterchoice then the hyper 212+?
