Ball mouse for gaming, still made?
GRAFiZ
I'm looking for a high quality "ball mouse" for gaming, mainly FPS. Tactile feedback.
Anyone know of a current production ball mouse, something high quality?
Thanks!
PS - Price is of no concern.
How about a mouse pad with more texture for tactile feedback? No? Probably not.
Yes your best bet may be to go used.
really, ball mice suck lol. Nearly all gaming mice are now laser, all of them brought out now are laser. But, go second hand if needed.
I don't know why anyone would really go with a ball mouse regardless of the reason, unless of course it's to deal with enviromental factors... but anyways.
Your best bet would be to go with the Boomslang, it's the best you will find thats still ball operated. Now I've heard rumors way back in the past that they want to make a new generation ball mouse with lasers... who knows how that is going to work... but may not work that bad.
Logitech sells some gaming laser mice that have weights in them.. you can even change the weights to your liking.
Ball mice are junk compared to optical.... and Laser mice are way better then the regular optical mice.. especially for gaming.
And wires... ewwww.. I haven't used a wired mouse on my system for about 7 years now.
Cut the hole in the bottom of a laser mouse, and put a ball mouses ball mount in the bottom.
Done.
Trackballs kickass for FPS gaming.
I use an old Logitech marble mouse. They require more specific sensitivity tuning than the laser mice, but you get much less wrist strain and IMO once trained, you are much more accurate because you only have to move the ball a centimeter or so with your fingers to get perfect shots, instead of a flick of the wrist.
I use http://www.newegg.com/Product/Product.aspx?Item=N82E16826104108&Tpk=marble+mouse this old thing. Trackballs are also hellacious on BF2 airplanes/helicopters!
u could try buying a trackball and using it upside down :p
ROFL
I could give you a few used ones in good shape for free if you pay for shipping.
I have a few I wouldn't mind sending away, too, but I doubt they're good for gaming. Dell still sends ball mice with their baseline systems. I have one of those (from work) if you're interested, lol.
I used to use the big ball, optical type of trackball for FPS gaming. I was pretty good. When I switched to an optical mouse I got even better.
Thats the exact mouse I am using and it is fine for gaming (imo). I play bf2142 so basically bf2 with a skin.
