bigdogchris
- Feb 19, 2008
I misspoke, I mean cloud saves to be used cross platform.Why would cross platform be removed from steam? I'm not sure I understand the reasoning. Do you have a source behind this?
It sure does. It has widescreen support natively built in. They also have an "in testing" big screen mode which really zooms out the game (but messes up the main menu a little).Does the Enhanced Edition support widescreen resolutions?
How does multiplayer work for this game? Can you play the full game in co-op?
Right now, you have to know the players IP, which means local LAN works best but if you know your way around a router (and port forwarding) you can set up to play across the Internet. They are putting together a matchmaking server that will hook up players online to play together. It's being tested internally right now, with more news coming soon.How does multiplayer work for this game? Can you play the full game in co-op?
Is everyone on PC or are some on iPad? Also, do they have version 2012 of the game, as there have been significant improvements in the past couple of patches.It's practically unusable with 3+ players, but seems to work ok with just 2. My friends and I are eagerly awaiting a multiplayer overhaul.
My personal preference is the stand-alone version as you get the updates the moment they are pushed live. Plus it's nice not having to run any type of DRM running (not Steam). The Stand-Alone requires a 1 time online activation to use the updater, which you do when you buy the game, but the game itself is a fixed EXE, so you can copy out the game contents to a thumb drive or whatever and play it anywhere. When you want to grab the latest patch connect to the internet, and run the launcher. Then just copy the data back over.
Mods that are bug fixes are not required as almost all of those types of bugs were fixed in the source code.What about mods? Do any of the old old mods work or have things changed enough that they need to be redone/tweaked?
$9.99 On Steam... get it.
Oh notice major Screen, flicker, found out you have to create a game profile an have Tripple buffering off, sometime Mouse hardware accel off to get rid of it. FYI.
You can do it at level 2 but it really depends on how many are in your group. Try to focus on one spider and keep a few back for ranged support. Have a few potions on the melee's.Should I be depressed that I can't seem to not get wiped out by that house full of spiders early in the game?
You can contact support email and they will be able to get you access to the other version.It looks like through Beamdog the PC and Mac versions are separate purchases. Does anybody know if that's also the case with Steam? Am I wrong about the Beamdog versions?
