Hi,
I normally use my computer for gaming and heavy multitasking in connection with programming( compilation of large programs, running in debugging mode), and in the future also some archiving of tv recordings (MPEG-2 -> MPEG-4) from my HTPC .But the real reason im upgrading is to be able to play MTW2 in its full glory
I have nice Watercooling setup with a 1m x 60cm passive radiator (external naturally), and i want to buy a really fast conroe system without spending an excessive amount of money.
I live in Denmark and the following approx prices apply for CPU's: ( 6DKK ~ 1$ )
E6300 - 1350 DKK
E6400 - 1650 DKK ( + 22% vs 6300)
E6600 - 2300 DKK ( + 70% vs 6300)
I am unsure about which of these to choose, i have the impression from this forum that all of these CPUs goes to about the same frequency when OC'ing( though the database seems to say otherwise ), so now im wondering how much those +2MB of cache is worth for development work.
Furthermore im a bit confused as to what mobo to choose, i dont want to buy an expensive unless there is a good performance reason to do so. Among the reasonably priced ones are the Asus P5B ( 950 DKK) and the Asus P5B-E ( 1080 DKK ). The 975X boards are more expensive starting at 1300-1400 DKK.
Finally there is memory, it seems that there is little price advantage of 667Mhz RAM to 800Mhz RAM so im stuck between CL4 and CL5 memory. How important is this difference, ie how much is it worth paying to go from one to the other? Is it for example better to forget CL4 and just buy even faster memory? The price i have found seems to be:
800Mhz - CL4 - starting at 2300-2400 DKK for 2x1GB (though some G-Skill CL4 should be available around the 14/11 for 2100 DKK).
800Mhz - CL5 - starting at 1600 DKK
1000Mhz - CL5 - starting at 2500-2600 DKK
Im looking forward to finally upgrading (my current gfx card is a Geforce 4600 and the CPU a Athlon XP 2500+ OC'ed to 3200+
so i hope someone will help me out
I realize some of this might be covered on this forum already, but my problem is how to balance the spendings based on the above prices, for example a E6600 with 800Mhz CL5 RAM vs a E6300 with 1000Mhz CL5 ram or 800 CL4 etc.
E6300 - 1350 DKK
