exactlyI like that box alot. I was checking that case out on newegg last naight. You just sold me on it. Did you do some kinda of a psu mounting mod?
EDIT** I see it just has a power plug extension to the front
very beautiful effectNice job of putting so much into so little!
I like how the 5850 sticks out...looks good.
exactly this the aim, to give a reason to this caseWow nice job. Gives me a reason not to throw this Apex MI-008 Ive had sitting here for over a year away.
So you moved the PSU to the front right? are temps better that way?
I have the Sugo....but it does not enter in my personal bagit's not that smaller than an SG05 though, and well, apex mi-100 $50, ST45SF $80 so it's actually more expensive unless you already have an apex case
torr3nt, did you make that bracket for the extension cord or did you buy that somewhere?
Also --- isn't there enough room to turn the PSU lengthwise? According to Newegg, the case is 13" long - 6.7" for the mobo so 6.3" -- taking the front into consideration, that looks like another 1" off, so 5.3" -- the PSU is ~4.9".
An italian link??Can you provide links to the cable parts?.
Yes adhesion paint, paint and Dremel for everything.And, did you use the Dremel for everything? It seems like it should be powerful enough to do that. I'm interested in trying this myself, though I've never attempted any case mods.
For cpu-cooler I have thought to use a Scythe NINJA MINI Rev.B but he is unavailable in Italy and I do not know if he is compatible.If there is anything that could be improved on this design -- if you've got a CPU cooler that pushes air vertically, you might want a vent on top, could probably cut open a 120~140mm space open to mount a fan or even just a grille.
Any particular problem but however I have undertaken an upgrade, grille 140mm with cpu-fan in extractionawesome job! that is some great power in such a small box. hows your temps when gaming?
