Hello everyone,
I'm having an issue with my rig that I just can not put my finger on...first of all, this is the issue:
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc). If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 00000099, A PTE or PFN is corrupt
Arg2: 00117409, page frame number
Arg3: 00000000, current page state
Arg4: 00000000, 0
Debugging Details:
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
MODULE_NAME: nt
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 42250a1d
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x4E
This happend on 2 new installs of XP, so I know it's hardware since my mobo,ram, and vid card carried over.
I have found a consistant way to get kicked to desktop, this should be important in the solution. When starting BF2, all is well until I start loading a map, every time I get to the "loading geometries" at 58% it kicks me straight to the desktop with no errors in the event viewer. This makes me wonder what's taking the brunt of that "load" at that precise time, is it the cpu or gpu?
Here's what I've tried:
Put my system back at stock, no oc,ing at all.
Ran memtest for 6 hours, no errors, replaced with other ram, obviously, still the same.
Ran stress test on Prime 95 -blended-for 8 hours, no errors on the cores or ram
My voltages are rock solid along with my temps, this cpu has never hit 43(temp)
Any advice/opinions are greatly appreciated, thank you.
K8N Neo4-F
Opteron 165@2.4
X1900XTX
2GB Patriot 3200
Antec Truepower 550
Arguments:
Arg4: 00000000, 0
Debugging Details:
MODULE_NAME: nt
BUGCHECK_STR: 0x4E
K8N Neo4-F
Opteron 165@2.4
X1900XTX
2GB Patriot 3200
Antec Truepower 550
