BadAxe2 Power Connectors
TechLarry
RIP [H] Brother - June 1, 2022
Ok, the Intel manual isn't totally clear on this. Are the statements below correct:
1. You have a 20 pin connector Power Supply:
  • You have to connect the 20 pin connector to the 24 pin socket on the MB
  • You have to connect the 12v 2X4 (or 1X4 with the 2X4 adapter) to the 2X4 connector
  • You have to connect the 1X4 (drive type) connector to the 1X4 IF you have a video card drawing more than 75 watts.
2. You have a 24 pin connector Power Supply:
  • You have to connect the 24 pin connector to the 24 pin socket socket on the MB
  • You have to connect the 12v 2X4 connector (or 1X4 with a 2X4 Adapter) to the 2X4 socket on the MB.
  • You do NOT have to install a 1X4 feed to the 1X4 socket on the MB, regardless of configuration
Do I understand this correctly?
Thanks
Basically if your psu has a 24 pin plug you dont need the extra 4 pin molex connector. You do need the 4 pin molex if your psu is only a 20 pin and your video card draws more than 75 watts of power.
So yes, you're understanding it right.
