Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When i turn my speakers up loud with nothing playing through them i can hear this beeping noise that kind of sounds like temp warning or something. nothing i do makes it go away. not sure why its there, upgraded all drivers but nothing works
if your refering to my speaker wire after it plugs into the computer that shouldnt be the problem, ive never had this before and it only started when i got my new system:
abit ic7
2.8e
512 pc 3500ddr
and its present in speaker and in headphones.
